1 - 7 of 7 Posts
Does anybody know if there is a way to adjust the media center info for larger tires or are you stuck with the stock tires specs installed in the computer.
Until someone comes out with a tuner (which I'm no longer holding my breath for) you're stuck with the stock tire size programmed in.
Actually your wrong, hypertech makes a speedo calibrator for the 11 trucks, its about 200 bucks and it will also do gear ratio changes
My dealer said they can go up 2 inches in most cases. And get it close. I would rather buy the hyper tech tuner. I don't trust my dealer.
+3 on the Hypertech, I'm also using it.
BTW Your dealer cant go over stock tire sizes.
1 - 7 of 7 Posts
