Okay so I have another thread on here titled "Truck Sluggish to Fire Up" and I detailed that my truck was cranking fine and has new OEM spark plugs but was stumbling/hesitating before finally starting. As if it was not getting gas.
Member "Zlow28" suggested the fuel pump was going bad and he may be right but I now think its a computer issue relating to the fuel pump.
Now, I was driving home from work yesterday truck is driving perfect then suddenly it was as if the engine/transmission/throttle were all disconnected from each other. It seemed like I was shifted into neutral, the engine was still running at idle but hitting the gas pedal did nothing. The screen said "shift to park to start". So i coast to the side of the road shift into park and it wont let me shift out of park. So i turn the truck off then on again and it starts running normal again except I have a check engine light.
So i drive to AutoZone to get the code and I get the following:
U0109 - LOST COMMUNICATION WITH FUEL PUMP CONTROL MODULE
P062A - FUEL PUMP "A" CONTROL CIRCUIT RANGE/PERFORMANCE
U0140 - LOST COMMUNICATION WITH BODY CONTROL MODULE
The fuel pump communication code came up twice...not sure if that matters.
Anyone have any ideas? I hate going to the dealer because they know they have your balls in a vise especially if it is a computer issue.
Truck is a 2013 with about 70K miles and 2220 total engine hours.
