I went to an automatic carwash this afternoon and when I got home I noticed a small amount of condensation/fog on the inside lens of my driver's side headlight. I have not noticed this before after having my truck washed. The outside temps here in Michigan have been in the low 30's and today it was 32F when washed. When I put my truck in my insulated garage, which is only about twenty degrees warmer than the outside, the condensation disappeared in about ten minutes.
I have the quad headlights and the condensation was only near the corner on the lower headlight and on the other corner by the turn signal. There was no water sitting inside the headlight and no water spots were left inside the lens. Is it possible that the headlight lens was really warm when it was sprayed at the carwash and the heat of the headlight on the lens may have caused condensation to form on the inside of the lens if it was sprayed with cold water?
The driver's side was power sprayed by the attendent before being sent into the wash and the headlights had been on for a long time. I did not notice a problem with the passenger side.
I hope it is a fluke temp thing. Just don't want to have to have a headlight assembely replaced. Truck is only 7 months old.
Long post, but looking for some answers or if anyone has experience the same problem. I am going to try and duplicate the problem later today as temps are supposed to be the same.
Thanks
Thanks
