1 - 2 of 2 Posts
Hey guys I need some opinion on what you might think would be the problem.
Today I was driving and heard a noise I pulled into a parking lot had my friend check the motor while I was accelerating and all the sudden coolant start pouring out near the pulley on the lower front of the motor here is a picture please tell me what you guys think.
Did you check you Oil and see if you have water in the oil? If there's no oil then check your water pump. Under the water pump there's a hole and usually when there's a sign of a bad water pump you will see water come out of the hole. Keep looking around for broken or bad seals. keep that 4.7 water and cooled any slight of over heating and the future might not look so bright for the engine.
1 - 2 of 2 Posts
