I have a 2014, obviously with the 3.6, that currently has 41,000 on the odometer. This past weekend, the check engine light came on, when I pulled the code, came up as P026AB. A little research leads me to a coolant bypass valve, the 3-way on the passenger side frame rail ahead of the motor. The dealer wanted 3 hours labor at 115 an hour to replace it. It's literally two 13mm bolts and 3 cooling lines. The part is expensive, around 300. I've currently got a call in with Ram, we'll see if they'll be of any help.
Has anybody replaced one yet? Where did you find the part, aside from the dealer? I absolutely refuse from now on to step foot into that dealer again.
