coolant level?
466 views 5 replies 3 participants last post by  Garc
#1 ·
Hi All, I have 2017 ram 1500 w/5.7... I am having some temperature issues... is there any way to tell if I am low on coolant? Any way to see the level it is at with my eyes?
#2 ·
Welcome to the forum.
The coolant reservoir (not the radiator) has a level indicator. On a cold engine remove the reservoir's cap and then lift out the level gauge. It will show the coolant level. If it is dry, fill the reservoir to the full mark on the gauge. Check it again on a cold engine after the truck has been driven and add coolant as needed. Make sure you use the correct coolant!
