1 - 7 of 7 Posts
i have a 2011 ram 4x4 sport, i am looking at just leveling it now with 5100 shocks , and putting on a new set of fuel hostage wheels and a set of toyo open county mt tires 33x12.50 x20. with a 0 or close to 0 offset. my question is will they rub and will i need spacers? and if in the future i decide to do a 6 inch lift will these wheels still work or would i need spacers ? i dont really like the idea of spacers and dont want to buy the wrong offset if i decided to lift it .
I think 0 offset is gonna put you real close to rubbing the upper control arm. I have 18mm offset and only have around half inch between upper control arm and sidewall. I have 33x12.5x17 Dick Cepek FCII's.
20x9 wheel with a 0 offset is 5" backspacing. You should be fine
If you decide to go 6" down the road, it depends on which brand lift and what tires you go with whether or not it'll work.
It should work IMO. I have a 4" lift with 20x9 0 offeset Fuel wheels and Toyo MT's and there is no rubbing at all.
1 - 7 of 7 Posts
