1 - 8 of 8 Posts
I'm looking at trading in my 2015 2500 6.4 on a new 3500. I tow a 35' 5er that has a gvwr of 11,000 lbs. I've done all the online building I can do on Ram's website but they aren't clear on some options.
  1. If I get the diesel with the Aisin trans, is it the 930 ft/lb torque rating with just that? Or, do I need to have the dual real wheel option as well?
  2. I heard you could only get 3.73's or 4.10's with a dually, but it looks like I can select 3.73's on the Ram site if I choose a Mega Cab short bed. Is that a mistake on the site or can I go with 3.73's if I go Mega Cab?
  3. Payload jumps quite a bit going to a Mega Cab 6' bed single rear wheel, is that because of the increased wheelbase?
Thanks for any help anyone can offer. I'd contact a dealer but it seams they never have a clue if it's not on their lot or something they can locate locally. When I start asking ordering questions, they look at me like I have 6 heads..
Craig
As far as I knew the single rear wheel diesel 3500 came with a 3.42 gear and adding either the 3.73 or 4.10 requires dual rear wheels.
The Hemi comes with a 3.73 and can get a 4.10 with SRW.
I bought a 2017 3500 Mega Cab SRW with the 6.4L Hemi and 4.10 gears, it's a Big Horn and and It has 4280 lbs of payload on the sticker (3900 calculated on scales with me and a full tank of gas).
Discussion Starter · #3 ·
Ah it looks like the Mega Cab is only available in the shorter bed but can have drw which explains the increased payload and gear options.
Still haven't found if I can get the 930 ft/lb torque without drw.
As far as I am aware, you only get the 930lb/ft of torque if you have a 2018, 6.7L Cummins, AISIN Trans, and 4.10 gears... Which requires a dually be added. I think there is a Max tow package that adds all of that, air suspension, and 30,000lb 5th wheel hitch as well on some models.
Moderator
As dboody said, SRW Cummins truck's only come with 3.42 gears (unfortunately). If you want 3.73's or 4.10's you'll have to step up to a DRW.
The 930 ft-lbs of torque should only require the Aisin transmission. You shouldn't need a DRW with 4.10 gears to get that unless they've changed something recently.
I'm sure you know, but one thing you'll want to watch is cab clearance towing a 5th wheel with a short box truck. A lot of guys have broken rear windows turning sharp. A slider hitch often takes care of that.
For about 6 years I hauled RV trailers from the factories in Indiana to dealers across the country. I did it with 1 ton dually diesels, 4:10 gears and an 8' bed. Unpleasant things can happen fast on the highway and for that reason I would recommend you purchase a truck with an 8' bed. As far as gears go do not go any higher than 3:73. Personally I would go with 4:10.
Discussion Starter · #7 ·
Yep, I have a Pullrite Super Glide for our 5th wheel.
Discussion Starter · #8 ·
So I got everything cleared up and pretty much exactly what everyone said here. Need DRW for anything other than 3.42's. 930 ft-lbs is with the Aisin trans, SRW or DRW..
I ended up getting an 2018 with the Aisin, DRW, with 3.73's. It's an absolute beast! I didn't want to go 4.10's because its also my daily driver and our 5er is only 11,000 gvwr.
1 - 8 of 8 Posts
