1 - 2 of 2 Posts
Hi guys,
I cracked the HEMI in my '04 2500 with a NV4500 vin code D on Friday. I've been searching locally for a low mileage take out but haven't had any luck. I live in Long Beach, Ca. Any help will be greatly appreciated.
Premium Member
March 18th Buena Park
http://www.socalcarculture.com/Images/PickersParadise2012.pdf
April
8th Long Beach - Hi-Performance Swap Meet & Car Show - Veterans Stadium
15th Pomona - Pomona Car Show & Swap Meet at the Fairplex
the Hemi engines had several applications
5.7
5.7 Hemi engineThe '5.7 L Hemi' was released for model year 2003 on the Dodge Ram 2500 and 3500 pickup trucks to replace the Magnum 5.9 engine. It also replaced the 8.0L V-10 engine in the heavy duty Ram. As of 2004 it was the only available gasoline engine in the Ram Heavy Duty. Chrysler has since made the 5.7 L Hemi available in all models of the 2004 Dodge Ram, Dodge Durango, the 2005 Chrysler 300C, Dodge Magnum R/T, Jeep Grand Cherokee, the 2006 Dodge Charger R/T, and the 2009 Dodge Challenger R/T. For Challenger, the 6 speed version will not feature MDS.
The 5.7 L (345 cu in) Hemi in the Ram delivered 345 hp (257.3 kW) and 375 lb·ft (508 N·m), but 340 hp (253.5 kW) and 390 lb·ft (529 N·m) for the 300C and Magnum R/T, which is exactly 100 hp (74.6 kW) more than the old 5.9 engine. It is a 90-degree V8, 2-valve pushrod design like the past LA engines, displacing 5,654 cc (345 cu in), with a bore of 99.5 mm (3.92 in) and a stroke of 90.9 mm (3.58 in).[7]
The 5.7 L Hemi is made at Chrysler's Saltillo Engine plant in Ramos Arizpe, Mexico.
The Hemi was on the Ward's 10 Best Engines list for 2003 through 2007, and again in 2009.
This engine is used in the following vehicles:
2003–2008 Dodge Ram Heavy duty, came without MDS, 1500s had MDS after 2005
2004–2009, 2011–present Dodge Durango
2005–present Chrysler 300 300C
2005–2008 Dodge Magnum R/T
2005–present Dodge Charger R/T
2005–present Jeep Grand Cherokee
2006–2010 Jeep Commander
2007–2009 Chrysler Aspen
2009–present Dodge Challenger R/T
1 - 2 of 2 Posts
