1 - 2 of 2 Posts
Ok here it goes, before my accident the c/c worked just fine. Now it wont even turn on. I have looked in the owners manual and the Haynes manual, but cant find a fuse that says its for c/c. I also looked through all my fuses and they were all good. Now it was a front end accident so I did replace the air bags, the airbag module and the entire steering column including a new clock spring that I put in the used column. I did not replace the servo under that battery. If that is bad would that cause the system to not even turn on? Another thing to add is of course my air bag light stays on never took it in to get it reset. Thanks in advance for any help.
Im going to say bad or miss aligned clock spring. If battery was disconnected and all sensor's good and hooked up right. The air bag light should be reset.
1 - 2 of 2 Posts
