cst lift spindle
6277 22
im looking at getting the 7 inch lift for my 11 ram...i noticed the spindle alone is about 1100$...i also noticed it looks exactly the same as the one for 02-08 which i found for about 800....so i did some small research and found that they have the same part number. i might be a little late but are they the same? if so why the price difference on spindle only sales?
1 - 20 of 23 Posts
When I was checking prices it was far cheaper to get the 7" kit instead of piecing it together and is likely still cheaper even if you found the 08-down spindles. Also keep in mind the 4" kit includes a billet 1" rear spacer as well as s/s brake lines, which may be where the extra 300 comes in.
Spindles/brake lines/ 1" rear spacer: 1100
+ leveling kit (2.5 inches) or lift springs if you don't have a hemi: 300-500
+ rear 4" spacer: 200
+ knuckles for rear: 100
total is 1700 - 1900 and comes to 6.5" of lift and being generous on the prices of the extra pieces
Complete 7" kit with shocks is under 1600 shipped on ebay. I hope this helps clear things up, I debated getting the 4" and then building it up from there but after realizing how much cheaper it was I decided on the 7" kit.
The spindles are exactly the same the only reason why the kit for the 4th gen is more is because you need the steel braided hoses which run about 100 bucks more, and depending what you do with your truck dont run the 7 inch kit, i have the 6 inch in the truck pictured below with a top gun customs 2.5 inch spacer in the rear with procomp shocks and it works great, the reason why i say dont run the 7 inch is because the shocks are absolutly maxed out with 3 inches added to the spring and if you go offroad at all and the shocks try and jounce it makes a terrible noise and rides like shit, with the 2 inch spacer and the spindle off road performance is do able desert performance is great i can give you more info if youd like just pm me or something
You cant add a shock to the front because the 2WD uses the shock as a droop stop so if the front hangs lower than the shock wants to the upper control arm hits the spring hat and it over pivots the balljoints, its just a bad situation all the way around , the rigors of lifting a 2WD haha
Discussion Starter · #13 ·
very nice truck...is it 2wd??....only reason i though just buying spindles only was cause i can get the 2 inch spacer and the rear spacer locally cheaper that i can online...how tall is ur truck? and what wheel/tire combo are u running?
yea its 2wd with 6 inches total of lift in the front and 2.5 inches in the rear if you run just the spindle just do a 1 inch spacer in the rear that CST offers it will sit perfectly level i buddy of mine has it the CST 4 inch kit on his truck im telling you the gaps are identical front and rear and he clears 35s with 4.5 inch backspacing its kind of tight but no rubbing on my truck im running 35x1250x20s on 20x10 Hostages with 4.5 inch backspacing as well:smileup:
Discussion Starter · #15 ·
damn i rally want the kit...but for now i think im gonna get jthe leveling spacer for the front and throw some 33's on it til im able to get some extra cash
Topguncustomz.com get the 2.5 inch spacer for the rear with procomp 927543 shocks in the rear it rides peeeerrrfect trust me !! and if you want to get really into it call tuff country suspensions and get part #34100 and all the hardware for it then the rear of you truck will be flawless
Discussion Starter · #18 ·
im sory but im completley lost....i cant seem to find the rear coil spacer on topgun customz...and the part number for the tuff country is for a 4wd...mine is 2wd regular cab.
OOOOKK bear with me here, the only difference between the 4wd and the 2wd is the obvious differential and axles and front cross members but the back is exactly the same in every way shape and form, when lifting the rear end more than one inch in throws the rear suspension geometry out of wack ( track bar angle ) if the track bar sits at too much of an angle it pulls the axle towards the passenger side. with all that being said if you go to topguncustoms 09 and up 4wd section you will see a wide variety and sizes of rear lift spacers most for rite around 80 dollars the procomp shocks are good for stock to all the way up to 3 inches of lift and are cheapest from summitracing rite around 5o bucks a piece if i remember rite and the rear panhard bar drop bracket is about 80 bucks , the alternative to all this is to stick with the pre-made kits CSTs 4 inch or 7 inch kit or you can make your own its really up to you. Just remember if you do a body lift you can never run tow hooks and your tow package hangs down like some old saggy balls , you can make a 2wd pretty big and still ride reaaaly good just have to plan it out
If you look at the pics i posted look at the pics of the rear the panhard bar is perfectly straight even tho the rear is lifted 2.5 inches thats your goal, and all of top guns spacers go on top of the springs ( thats pictured too ) so if need be you can run helper bag if you need em for towing toys
1 - 20 of 23 Posts
