1 - 3 of 3 Posts
Discussion Starter #1
I wasn't sure where to put this thread, but I have a few questions and apologize if this is in the wrong spot.
I have an 07 Dodge Ram Single Cab which I acquired cheap (aka no bells and whistles). Now I want to put in the basics : power windows and power locks. There are lots of kits out there, and I was wondering if anyone could point me in the right direction for a quality one. I am a DIY-er, but if its really difficult will bring a pro in to do the job. I just want to make sure I supply them with a solid kit.
Power windows : I am looking for a strong and reliable motor. It does not have to be quiet, just work every time all the time. I saw some cool switches out there that turn the crank into the "button" and plan on using that. But I want the guts inside the door to be solid. The switch is here, but I'm not sure of the kit. I was looking at this but would love to know what has worked for other members :
Kit :
http://www.thehoffmangroup.com/autoloc/powerwindowsconfigure.lasso?step=universal
Switch :
http://www.thehoffmangroup.com/autoloc/product.lasso?prodinc=electricwindowcrank
Power Locks : Not so important to me, but if the panel is off for the window I want to install them. I want the basics for this, don't even care for a button. I've seen some kits that the driver door controls the passenger door, IE if you pull the plunger up, the passenger side goes up; push it down the passenger goes down. If I have a remote and that operation, I'm satisfied. My concern is the same here, I want it to be installed, and then work, and keep working.
Has anyone had any success and can you tell me what kit you have used? Thanks in advance.
E
Why not go OEM? Everything should work fine, it's plug and play, and it has a warranty. Of course, it will probably be more expensive than what you found.
1 - 3 of 3 Posts
