21 - 24 of 24 Posts
Sadly my 2012 is doing the same thing now. 173000 miles. But I can not afford a new motor like dodge says. I know it’s a lot of miles but can’t I just do a new camshaft???
Depends on how far metal worked it’s way through the engine if it made it past the filter your bearings are then toast. Search for this issue ,you can have a clue when you speak with the dealer.
Hello everyone, 2016 Dodge Ram Big Horn 6 cyl. Just had this issue come up yesterday. All of a sudden felt like driving on rumble strips and the stuttering. Backed off and it went away, went to pass and it started again and got the check engine light. Thought bad gas like everyone else but took it in for a code read today and its the misfire cylinder 3 code. My 2016 has 132,000 miles on it and out of warranty. From those of you who have had the work done could I get a heads up on $$$
Hey ChemCop, did you ever get yours fixed? my 2012 big horn is doing the same. how much did you have to pay?
2012 Crew Cab SLT 4x4 5.7 Hemi
Was it maybe made in 2011? That's the year most of the affected trucks seem to be.
Dang… my ‘12 shows Mfg Date: 9/11 with 124,546!
need to look into this UOA you mentioned. And research proactive things I can do now. I need this to last another 5yrs at least.
21 - 24 of 24 Posts
