1 - 5 of 5 Posts
My dash lights Started to randomly flash of and on then I found the dimmer wheel to not have a detent being able to position it right between light and dim..
Anyone else have this happen??
Super Moderator
The rheostat has detents at the ends of adjustment, everything between those is a fine tune adjustment
Mine flicker when set near the low end of the dim setting. I'm not going to the dealer for this. I just bump up the brightness to a point that they don't flicker.
Yeah, mine sometimes flicker on lower settings also. Have done so since the truck was nearly new.
My wife likes them brighter than I do, so it gets moved back and forth semi-regularly, and I think that may have helped to reduce the flicker.
1 - 5 of 5 Posts
