1741 - 1754 of 1754 Posts
Hi. Is there a wire diagram that will make the auto dual zone work in a ra2 to ra4 upgrade with 7 speed setup in 17 ram 1500? I font know if this has been done yet.
Thanks in advance
So I just looked on the oem parts co website, now known as infotainment, and they apparently are going to be shipping kits out at the end of May that have everything you would need.
Can anyone verify that their kit will give us all the same functionality and everything if I were to source all the parts separately?
When I look at the list, it appears to have everything except the resistor, but I could be wrong. They are going to be selling the kits for around $1600.
I know this is older post/thread, but thought I would post my experience using the infotainment kit. There are three options, no nav, basic nav, and 3D nav plus HD and extra SiriusXM goodies. I went ahead and went the the upper tier 3D/HD package - figured if I was going to spend this much I might as well go all the way. The price currently ranges from 1200 to 1600 depending on which unit you choose. (don't freak just yet, more price info below)
Package includes head unit, replacement bezel, HVAC controller and cable, and 911 plug All parts looked new. The head units are reconditioned units with 90-day warranty, with a 1 year option available. This is the kit for the 7 speed fan, and upgrades you to the nicer controls also.
Mine arrived today, and within an hour pretty much I was done. It's a very simple install, really. Disconnect battery, mount HVAC controller, route cable, pull bezel/radio/plugs, swap bezel, mount new unit and replace plugs reconnect battery. That's it - you'll need to transfer Sat over, and may need to drive around the block to calibrate the NAV, but otherwise you are basically done. I stopped for a few minutes as I cut my finger pretty good routing the HVAC cable so it's basically an hour or less. The only minor issue I ran into is that the main harness for the radio the wires come out and bend one direction - when swapping the radio those wires were set in that bend which prevented really getting a bit with the lever to latch it in, so you just swap the lever to the other side (so you are not fighting the bundle of wires) and it drops right in.
As advertised, everything works as expected. Nav directions display in cluster, steering wheel controls all work, you can use touch or manual contorls for radio, HVAC, etc. Backup camera is so much nicer on the 8.4 vs the 5". Then there's HD Radio and SXM Travel/Traffic which I haven't even messed with yet.
So, the elephant in the room... the price. yes it's expensive. I didn't read the entire thread, but I suspect you could source the parts from here and there and save a bit of money, but with this kit you get everything in one box. They take your VIN and set it so to make sure there will not be any conflict or issues. I got a radio same year as my truck, and everything is guaranteed to "fit". They have a warranty, and support if required.
They also offer a Mil discount, and will take your radio on trade in as well. So with the Mil discount, trade in, and factoring in I also returned the hang on the window GPS I had just bought but not opened, the price falls quite a bit.
So overall a thumbs up from me. I know some will prefer to source items and do everything on their own, but I'm happy with the kit and having it in the truck 2 days after I placed the order. :smiley_thumbs_up:
Congrats on the upgrade, it's definitely a worthwhile investment. I pieced together the 8.4 upgrade right after I got my truck, no regrets.
Hi I'm in the process of swapping to a 8.4 nav radio from the 5in I was able to get a bezel with auto climate control I can't plug in the adapter for the fan/climate controls the new climate control has an 8 pin female connection does anyone know where I can purchase an adapter or what can be done? I did connect radio to try it out and everything works I have a 7 speed fan and steering wheel audio controls if that helps. Any help is greatly appreciated
I got a VP4 NA from infotainment from a 2017 ram 2500, which I put in my Canadian 2017 Ram 1500. Everything works but when I try to register with SiriusXM Canada they said the radio is not compatible with Traffic + Travel link. But my last radio in the 1500 2017 was VP4 CA and I was able to get Traffic and Travel link but the issue was both services did not show up (icons missing and under subscriptions it was only subscribed to XM select but online I had all 3).
I called XM Canada and they said when they looked it up they cannot add traffic and travel link as its incompatible...
Anyone know what's going on?
I currently have 2017 1500 Trademans with 5" RA2. & 7 speed fan.
Parts I have ordered.
Control 68183973AC
8.4 Uconnect VP4 with Navi.
New bezel(None-Dual).
And I need harness.
Please provide information for a payment.
[email protected]
On the harnesses I've been building, I solder the splices and crimp the plugs. You take the 24 pin plug you unplugged from your 5.0 hvac bezel and plug it into the harness and then plug the other end of the harness into the hvac module and the 8 pin plug into the new 8.4 bezel.
Now that I've thought about it, I understand why the hvac module I posted doesn't work on high. The 2013s are wired that when on high, it bypasses the resistor. Sorry to everyone who bought that part, you might be able to convince whoever you bought it from to swap it out for the other module.
I don't have my truck (still at the tow yard) so I can't test anything out.
Control 68183973AC
And I need harness.
[email protected]
I have been looking at this as well, I have a 2018 with the 5", after you changed out the radio, did you add the rear cargo camera also? did you have to change out your rear view mirror for the radio ? mine has the basic rear view mirror.
I have a 2013 Ram 1500 that I want to upgrade to the nav system with all the bells and whistles but I have the 4 position fan switch do you know how I would handle that problem?
Any one know where to get the audio wiring diagrams for thew 2019? I cant find on the dodge site. I just ordered my new truck ,and I plan to add an AMP and sub, along with a drop down DVD for the kids.
thanks
thanks
Ask your dealer parts guy, they can print out the factory parts diagrams and service docs.....ok, they don't have too but most will..
Is there anyone out there that can give me and pin layout 5 .0 to a 8 .4 for 2018 ram tradesmen donar is a 2015 8.4 with nav all working the 5.0 bezel not seated good . only vol is on steering wheel. i have 8.4 bezel and ac control module but no harness. i have everything to make it but the pin layout .oh it is a 7 speed fan
