1 - 2 of 2 Posts
The head lights, fog lights, radio, and dome lights only work when the key is in the run position. This morning everthing was working fine minus the radio do to a pin in the radio harnes. I pulled the radio to replace the pin in the connector and reassembled. I have been threw all the basics, checked the off draw fuse what would be the most probable and have had zero luck. can somon help me obtain some clear diagrams.
this is a 2003 dodge ram 1500 4x4 quad cab with a 5.7
There should be a separate Acc. Fuse I dont know about the newer trucks but there is one either under the hood in the power distribution box or the dash or both?
1 - 2 of 2 Posts
