1 - 2 of 2 Posts
Have a 2005 Dodge Ram. The drivers side front door is the only door which the door lock will funtion properly with door lock switch and key fob. Front passenger and rear drivers door must be unlocked manually and the rear passenger side door the door lock is stuck down AND the electric window will not work at all (window switch on rear passenger door or drivers window switch neither on will operate it). What is going on. Again only drivers door works properly. Rear passenger lock is stuck down and other two must be pulled up manually plus rear passenger window will not work.
1 - 2 of 2 Posts
