1 - 7 of 7 Posts
Hey guys so one day when I went to unlock my truck as I approached it the driver side door did not unlock. After pressing the unlock button several time they unlocked. Did that for a few days and now they will not lock or unlock via the remote. The passenger doors will. Also my radio only works now and then. The radio itself works like with bluetooth which is about all I use, but it's like the antenna is being unplugged and plugged back in. Any ideas? Especially about the doors.
My 2012 just started to do the same thing with the drivers door lock.
The FOB unlocks the drivers door sometimes and sometimes not, but always the unlocks passenger doors.
I thought it was just my FOB battery going dead.....
....I am beginning to suspect the solenoid or a loose wire.
Premium Member
Your FOB communicates with the BCM, Body Control Module
I think the BCM is located some where around the left front fender & door, ( drivers side )
in the area of the E-brake pedal
When i had my 2009, the dealership Re-Flashed the BCM & it worked a bit better
When my doors would not unlock, i pushed the Start Button on the FOB & when the Ram started, i knew that the FOB & BCM were communicating
I could always unlock the door after the truck started
1 - 7 of 7 Posts
