1 - 14 of 14 Posts
Premium Member
Lower the window all the way down and hold the button down for 3 or 4 seconds. Then raise up the window and once it is up hold it for 3-4 seconds. This should reset the auto up/down features
Mine also does this from time to time......it quits working then.....BAM, its working again, kind of like my back up camera.
Premium Member
I have had my 2016 Ram Big Horn SLT 1500 since January 2016
Should it have the Auto Up feature ?
How does it work ?
Super Moderator
How does it work ?
Yes. When you pull on the switch the window goes up. If you pull it past the second click then it will go up automatically even if you release the switch
Mine goes through fits over the last month or so; it'll work, then stop, then work again. There doesn't seem to be a rhyme or reason to it.
I have a 16 Laramie that I bought new. My driver window did the same thing. Thanks for the info, working correctly now. Has there been any recalls about this?
This just happened to me friday morning last week. I put the window into auto up and as it was going up i hit a bump and it stopped and went back down. It took 2 days of just normal use before auto up would work again normally. Auto down worked fine.
Super Moderator
Maybe a TSB, it won't be a recall because its not a safety issue
1 - 14 of 14 Posts
