I have an ongoing headlight issue, I installed an Opt7 LED kit in my 2012 ram 1500 sport,about 2 weeks ago, I replaced the fogs, as well as high and low beams.
Problem is my DRL on my Passenger will not light/stay lit. I am in Canada and DRLs are mandatory. When I put truck in gear the drivers side DRL comes on every time, the Passenger side DRL will come on and go out 1 or 2 times then stay off or not light at all. I have bypassed the factory headlight plug that seems to cause issues for other people and swapped everything from one side to the other to eliminate the possibility of faulty equipment.
It gets weirder, when the lights come on at night automatically everything seems to work most of the time, I just can't get that one DRL to work properly on the passenger side!!
I have read that the truck will output a lower voltage to the DRLs and full voltage when the lights are truly on. but if I turn the lights on with the switch manually I am still stuck with the intermittent problem. I am by no means an electrical expert, I have read some things on "Canbus" etc. but do not fully understand, I am praying it is not the TPIM. I also do notice some flickering but can't be noticed from the drivers seat. The install also included capacitors.
If anyone can provide some insight I would be forever grateful, this is my first post to this forum so if I forgot anything please feel free to let me know.
Thanks!
Thanks!
