1 - 2 of 2 Posts
Discussion Starter #1
Does anyone know the part number for the 2010 ecm. i want to swap mine but i cant find anything about it.... or does anyone know if this is even possible
I think the biggest hangup your running into, is the lack of an ECM. In the 2010, they use a PCM (Powertrain Control Module) the does all the functions of the earlier ECM and a bunch of others thrown in for good measure.
If you try to swap it with a different unit, your truck will likely not run as these units are VIN matched. When the dealer replaces one (to replace a defective unit), they must connect to it with the scan tool and program if to the VIN in order to have the unit functional.
Why were you looking to replace the ECM?
1 - 2 of 2 Posts
