1 - 2 of 2 Posts
Problem solved Electric cooling assist fan problem - no power to circuit
Problem solved, disregard.:smiley_thumbs_up:
Hi all,
2010 1500 TRX4 with 4.7, 175,000 miles. Had to replace the radiator and also found the electric cooling fan connected to the radiator was not working. Found a bad place in the wire where it went into the fan motor. Replaced it with new motor/assembly.
There is no electrical signal coming to the relays to make the fan come on. My brother and I (he is the mechanic, not me) checked:
- new fan works with jumper wire (with inline fuse of course)
- fuse and relays are good (checked with power and ohm meter per instructions in the Chilton manual.) It has two relays - one for overheat protection, the other when AC is turned on - neither is getting a signal.
- Circuit from the fuse box to the fan is good.
- No loose connections that we could find under the hood
I realize this could be a ECM problem, but is there a sensor somewhere that could be bad?
I'd appreciate any ideas.
1 - 2 of 2 Posts
