My truck ran fine until the other morning it just shut off idling. Checked all the fuses all are good. When you turn the key on nothing, fuel pump don't run and some stuff don't work like wipers radio. I put a new ignition starter switch on since this happened, if I turn the key on and the turn signal with the four ways the throttle solenoid runs on and off as the four ways flash same with the wipers. Please help thanks!
