I recently started experiencing trouble with my truck. I fueled and went to start and it would not turn over. There was not a draw down on the interior lights or accessories except the for the radio. Also, the blower had switched and was blowing through the defrost vents rather than dash. The vacuum lines and everything under the hood was fine. I checked battery connections, fuses, relays and all seemed ok. I got in and rattled the key and tilted the wheel and just fooled with the steering wheel and ignition and it fired and the air went back to blowing through the dash vents. This seemed to be telling me its something electrical in the steering column though I am puzzled how the blower is involved.
I drove about 20 miles and was in heavy stop and go traffic towing a trailer and experienced the dead pedal - I pulled to the shoulder and the truck picked up and never has done that again. I checked codes and had the 216 and 121. The check engine light did go off and I had the codes cleared and they haven't been back. The truck has still been doing this since so it seems something has happened in the column.
I am a bit concerned about the VP44 but it seems like the starter should still engage even if the pump has failed.
I am pretty mechanical and done a lot of work on this truck but this one has me stumped.I would so greatly appreciate and guidance or advice in solving this issue.
Thanks in advance.
Thanks in advance.
