1 - 4 of 4 Posts
Discussion Starter #1
On my 1994 Dodge Ram 1500 4x4 I put a new motor for my wipers! Worked for a little bit, then stopped! I replaced the switch for the headlights, blinkers, and wipers! Watched the fuse blow! What am I missing??
My 89' was doing weird stuff with the wiper motor. I grounded the motor to the firewall and fixed it's woes.
If the fuse is blowing, there is absolutely no doubt you have a power shorting to ground. If its kind of an instant poof. If it runs for a bit then goes. It could be the motor is drawing to much amps. A poor ground in system may cause this. Add a case ground would be a quick way to eliminate this.
1 - 4 of 4 Posts
