1 - 8 of 8 Posts
Discussion Starter · #3 ·
i was looking around while she was running and didnt see anything.....turned on the heat and looked up as antifreeze sprayed all over my windshield.....must be a crack in that top rad hose somewhere
Your heater lines run into fire wall on pessenger side of eng id look there if it started after you turned on the heat.
Try heater lines they run in fire wall at pass side and if it started spray ing after heat was on there might be a rub or a pin hole
thank you it is nice when you find and post solution. somtime we wonder.
1 - 8 of 8 Posts
