Engine light going on when I fill up the tank
892 views 5 replies 3 participants last post by  VTL
#1 ·
Hi guys
This start happening to me.
When I fill up the tank to full the engine light goes on and when it goes down to half the light goes out.
Has anyone had this happening before?
#2 ·
Are you topping it off? If you are you may be getting evap codes which cause the mil to illuminate. After a few warm up cycles the pcm sees there is no longer a problem so it clears the light. Now if your not topping it off, sorry i cant help:doh:
#4 · (Edited)
Ok, not turning off the truck is the problem. If you open that cap with the truck running it registers a large evap leak. Then your mil stays on for a few run cycles, so turn the truck off when you fill up and you should be fine. Wow 70 cents for super lol, I wish that was here.
