1 - 5 of 5 Posts
My 2004 4.7 motor thumps when cranking over.
My sister had been using my 2004 and the water pump blew and the truck red lined and cut off as she was pulling into a safe area. I had it towed, looked it over and needed to move it.
Thump Thump Thump and then it turns over, the thumping resides yet doesn't go completely away and it sputters, no power to the master cylinder for brakes.
Not cracked any where
No oil leak/Water☠
Radiator and oil cooler intact..
Thank you in advance.
2014 345ci 8hp70 44-44 3.92 Truetrac NX Express Comp Greene Racing
Did it overheat? Heads may be warped, a video of the thump would be helpful.
Discussion Starter · #3 ·
Thanks for the reply, yeah but not for long! Ill check that and shoot a video. Ive had RAMs forever and a few over heated worse than this and never a thumping..
1 - 5 of 5 Posts
