1 - 3 of 3 Posts
Discussion Starter #1
I’m pulling my engine out of 98 dodge 5.2 the engine is blown. Do I have to pull both trans and engine I can get flex plate to rotate in order to take out torque converter bolts holding the tranny to the engine.
Flex plate rotates with the engine.
That is if the motor didn't throw a rod, If so it may be frozen. If that's the case you need to drop the pan and release whatever is stoping the crank from turning.
1 - 3 of 3 Posts
