1 - 1 of 1 Posts
Discussion Starter #1
I have a 2011 Ram 2500 Hemi. The EVIC display started flickering for a couple of days and then it went completely out. Now it will randomly come on sometimes or it might flicker and then go back out. If you look very closely you can see that the information is still showing up, but it is too dim to see very well. I’ve checked all the fuses and I’ve tried going through the EVIC menu options and nothing seems to work. I’ve also tried the dimmer options on the dash. Everything else works just fine. Any thoughts as to what is causing this?
1 - 1 of 1 Posts
