Never knew. Maybe my '14 doesn't. I plug mine in when the overnight temp is supposed to get in the 20's or so. At startup the water temp is 60+. After a couple of minutes the engine goes into a high idle. When I go out, 5 minutes after startup, the temp is around 100 and starting to blow warm air.
Be interesting to know if others have done it the way you described.
