1 - 2 of 2 Posts
I got smoke coming from the exhaust of My 2000 Ram 1500(sometimes thick white smoke other times vapor smoke) only when in reverse and it lasts a minute or two then goes away..doesn’t matter if the truck is already warmed up from going somewhere or not..it happens practically every time I put it in reverse..any clues as to what the cause is???
Did you ever figure out what was the issue with your ram smoking I have the same problem
1 - 2 of 2 Posts
