1 - 11 of 11 Posts
Does anybody have experience with it? Says its specifically designed for Hemis and also mentions larger CID motors. So the 392 seems like a great candidate.
Any info would be welcome.
Luke
No experience with 50 series, but love the 40 series. Great sound throughout the whole RPM range, interior sound isn't bad unless at 1700-1800 RMP...get a hum that isn't fun to listen to over long distances.
I just had a 50 series "big block" muffler and a black tip installed yesterday. So far it has a perfect deep tone with no drone at any rpm range. I left the resonater in place just in case. It's louder than stock but not obnoxious by any means.
Discussion Starter · #4 ·
Thanks for the input! Does it have a defined note or is it kinda sloppy?
Cold startup sounds a little hoarse...but once warm, that sound turns some heads. I put duals out the passenger side in front of the rear tires. Get a lot of compliments not only on the sound, but the location of the tips since no one can find them in front of the tires.
I put the 50 hd American Thunder on my 5.7. Perfect fit with no fabrication. It has a good rumble and sounds great when you get on it. But it is a little to quite for me. The outlaw is the same thing but supposed to be louder. Maybe I should have tried that one.
Discussion Starter · #8 ·
Had Flowmaster 50 on my 2014 6.2 F-150 FX4. Sounded awesome.
Liked the MPRB sound just a little better.
Later.....
Thanks for the input. I'm still torn. The local shop I'm going to use sells all major brands, but he believes for what I want the magnaflow would be best.
I hear good things about the Magnaflow. If you told them what you wanted sound wise I would take there advice.
Good luck man.
Magnaflow has a very distinct sound, some love it some don't. Would be nothing like a Flowmaster, even it both were about the same decibels. I have their entire cat-back kit (19200) and a number of people comment on how good the truck sounds.
I have the Flowmaster 50 HD. Deleted the results resonators and added black tips to my blacked out '15. I couldn't be happier with it.
1 - 11 of 11 Posts
