are this just your run of the mill 35W fog lights? A little more info about what type of lights, whether you installed 'em or someone else, etc would be helpful
If they are you should be able to tap into a fuse in that is key switched. Just be mindful of the amperage rating of both the lights and what ever you're tapping in to, as you don't want to overload the circuit.... this will cause major issues.
Another option is to use one of the empty spots in your fuse box, and tap in there. They sell kits at most auto parts stores that allow you to take advantage of this. You will need a little bit of electrical knowledge to pull it off though.
good luck
Exco
good luck
Exco
