1 - 2 of 2 Posts
(i am out of ideas)...
My fogs lights are stuck "on". Ive replaced the light switch, relay, fuses. Checked my cables (all intact).
When i test the output of the harness, when the fogs are off, both lines to the harness are no longer positive. (essentially when the fogs were off both feeds to the bulb were positive, when the lights were on, the "ground" actually goes negative and the lights power on).
Right now the line that used to alternate from + to - is stuck in the negative position thus allowing my fogs to run 24/7.
I also noticed that even when my high beams are on, the fogs stay lit.
To me this would suggest the relay, but swapping it out did no good.
1 - 2 of 2 Posts
