1 - 2 of 2 Posts
Discussion Starter #1
Looking for some help:
trying to fix the front end clunking that could be caused by Sway bar end links gone bad. Any thoughts for other ideas, please let me know.
Is it normal for the RPM's to fluctuate while traveling down the interstate (normally from 1700 to 2000). Do i need to do a trans flush or any thoughts on this matter would be greatly appreciated.
Glad to see you got your post up. I had an '06 that would show a RPM fluctuation in the gauge but didn't ever affect actual engine RPM. The dealer shrugged it off as there were no error codes.
On the tie rode ends, if they look bad and worn they should go. I put the nylon bushings on at about 90k on the '06 and boy did it tighten up the handling.
1 - 2 of 2 Posts
