Is the front crank seal on a 05 5.7 hemi under pressure or part of the pressurized oil system also I’m pretty sure I already know the answer to the next part but would a leaky oil pan gasket and leaky valve covers cause low oil pressure as long as it was kept nearly full of oil constantly or replacing all of them cause the oil pressure to suddenly be so high that it is causing the motor to now burn oil. I was told by a shop that now that the oil leaks are all sealed up it is causing it to burn oil
