1 - 6 of 6 Posts
I have a 2013 1500 quad cab. I have a chirping/squeaking noise coming from the front end while driving at all speeds. It seems constant but definitely is worse when I drive on a bumpy surface. I can't replicate the noise by shaking the truck while parked. The truck is driving and steering perfect. I looked underneath myself and can't find anything obvious. It's driving me insane, is anyone else having similar problems, if so did you figure it out? any advice would be appreciated. I'm trying to avoid the dealer I own a business and its hard for me to find a day for them to take the truck and search for it.
· Premium Member
2013 RAM Laramie Crew Cab
I haven't had that on my RAM. From the vid it sounds like one of the body mounts. I've read here that sometimes they are loose. I hope you find what it is. If you do update us.
I have a squeak when going over bumps, I don't notice it all the time, mainly with the windows down, radio down. Also makes the same noise when I shut the 2 front doors so I'm not sure if it's suspension or body panel, I notice the door pins are starting to squeak now too
mine sounded just like that too. turned out it was the shock that needed to be replaced and my dealer did it under warranty. all is good again
1 - 6 of 6 Posts
