sorry, i had assumed everyone knew about them.
Fronts: 0"-2.5" of Lift
this info is pulled right from Bilstein website.
Fronts:
Part Number: 24-186988
Old Part Number: F4-BE5-E523-H0
Setting: 5100 Series (Ride Height Adjustable)
Drive Type: 4WD
Position: Front
Body Style: Standard Cab Pickup
Body Style: Crew Cab Pickup
Number of Doors: 2
Number of Doors: 4
Quantity Per Vehicle: 2
*Collapsed Length (IN): 15.18
*Extended Length (IN): 21.26
*Collapsed Length (MM): 385.5
*Extended Length (MM): 540
Finish: Zinc plated
Reservoir: No
Body Design: 46mm ID snap ring grooved body (Coilover)
Bilstein 5100 Series Ride Height Adjustable Shock Absorbers are designed for front coilover style pickup suspensions. The monotube shocks feature a 46mm digressive piston with self-adjusting deflective disc valving. Multiple snap-ring grooves in the shock body allow for different spring seat positions, providing 0"-2.5" of front end lift, depending on application. Provides increased wheel travel and improved handling! (zinc-plated steel body, Triple-C-Technology? coating )
Rears:
Part Number: 24-185783
Old Part Number: F4-BE5-6682-H7;F4-BE5-6682-H8
Drive Type: 4WD
Position: Rear
*Collapsed Length (IN): 16.16
*Extended Length (IN): 26.14
*Collapsed Length (MM): 410.5
*Extended Length (MM): 664
Finish: Zinc plated
Reservoir: No
Body Design: 46mm ID smooth body (Non-coilover)
Bilstein 5100 Series Shock Absorbers are high gas pressure monotube shocks designed specifically for lifted pickups, SUVs and Jeeps. The shocks feature a 46mm digressive piston with self-adjusting deflective disc valving. They offer super damping ability that makes them ideal for heavy hauling or occasional off-road use, while maintaining an exceptional street ride. (zinc-plated steel body, Triple-C-Technology? coating
