1 - 5 of 5 Posts
New problem with the truck this morning... Fuel gauge says empty even after putting $50 of gas into her.
Gauge test with the trip reset button passes fine. What's my next step to troubleshoot?
Anyone know the labour time to replace the fuel sender?
Super Moderator
Fuel sender is in the pump unit so you have to pull the bed or drop the tank and replace the pump unit. Its worth doing yourself if you're up to it
Discussion Starter · #3 ·
Well, I fixed it!
I took a rubber mallet and gave the underside of the fuel tank some whacks and the gas gauge is working again! :)
go pick up somechevron techron fule additive and clean things up. i love thestuff. use it when the fuel gaugein my kids lesabre gets stuck.
1 - 5 of 5 Posts
