1 - 1 of 1 Posts
I had a new Delphi fuel pump installed by the dealer Sep 30th and about a month after that my truck wouldn't start. I disconnected the negative side of the battery and then reconnected it after about 45 seconds and it started right up and ran like a best, like usual. 3 weeks later it did it again and bu this time after the restart it had a small backfire (sounded like a carb backfire for those that know what that sounds like) and it died. After I reconnected the battery it ran great so I used my Trinity T1000 to return to stock and drove it a few days but it did it stock too.
I have been calling buddies and dealerships for info and 3 of them say there is a problem with the fuel pump relay module and it is no longer an under the hood relay like it has always been but it is the entire fuse relay under the hood which is between $800-$1000. I just dropped $624 on the damn fuel pump. Anyone having or know of someone that has had this problem ???
Any and all help is appreciated.:4-dontknow:
1 - 1 of 1 Posts
