Gear oil and another ?
657 2
I want to change my gear oil on both front and rear, whats the capacity of each?
Also I changed my thermostat because my housing was cracked, coolant temp went way up and then down, heat sometimes gets cold. Do they also sell a tool for the clamps?
1 - 3 of 3 Posts
Capacity on both front and rear is just over 2 qts. If you have a factory LSD then you need the mopar friction modifier in the rear. It's a 4 oz bottle you add in to the 75w140. Front is 75w90. Lose the factory clamps and go get some worm drives. They are much easier to work with and will be less expensive than the tool for the factory clamps. Any pair of adjustable pliers will work in taking off those clamps though, it can be a little bit of a pain but they do work.
1 - 3 of 3 Posts
