1 - 4 of 4 Posts
got a friend you replaced his cam sensor and the truck (V8) won't run. It ran just after he installed it but the next day wouldn't run. He talked with a repair shop and they told him the computer needed to be reconfigured. Sounded bogus but wanted to see what the group thought.
Typically a cam sensor wont keep from running. The cam sensor tells ECM to change timing if needed and fuel. Crank sensor is the guy that sends signal to ECM to fire coils/plugs.
1 - 4 of 4 Posts
