went to thepartsbin.com and talked to one of their sales rep through their chat thing and according to them and the Aries rep the Aries grille guard sku# ARS5054 was a direct fit to my truck via VIN number.
Is it only the plastic bumper that is different or is there something about the frame that's different? I cannot find anything short of a bull bar that will fit and I wonder if a full replacement bumper will mount up correctly.
I'm going to bump this post. I have a 2014 express and I want to know if anyone has rigged a HDX up and used all the mounts. If I have to do some trimming, that's OK, I just want it mounted properly. Thanks!
I have a 12 Express and at first i ordered a Ranch hand and it didn't fit. None of the brackets lined up, Then i got a Frontier and it did fit. All the mounting brackets are on the bottom, 2 were at the tow hook mounts, And 2 under the bumper I had to trim the valance. It works and seems sturdy but i guess i will find out if i hit a deer.
What i did, and recommend to most people is i custom built my own grille guard but i drilled a bolt in the tow hook that connects the grill guard to the tow hook. so this is not connected to the bumper so it should be easy to install on any car as long as you have tow hooks.
Ive emailed aries, go rhino, and Weston. Still no options for the express models without modifying the plastic bumper. Ive seen several places showing where these will fit but contact with the direct company says none of them will. Looks like I will be cutting into the front bumper to fit the brackets (as bad as I hate to) unless someone else has found one that will fit without modifying the bumper.
I recently contacted Ranch Hand about getting a grille guard for my 2013 Express. I was informed that the grille guard will fit, but you have to modify the plastic insert that runs across the bumper. Essentially pull the insert and trim it to allow the brackets to run through the bumper.
Honestly, if I wanted something rugged looking, and more importantly useful, I'd ditch the whole Express bumper itself. I'd look into a full on ranch hand bumper with the grill guard, tow hooks, fog light integration, etc. The Express bumper just is what it is, sporty looking. Doesn't even come with tow hooks.
21 - 33 of 33 Posts
DODGE RAM FORUM
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
