Headaches with 4x4
964 5
Hi all,
Back in November I rolled my truck, now after four time getting the garage to repaint the truck and recheck the front end I still have the same issues. When I put it in 4x4 and accelerate on pavement it pulls to the right hard, before the accident it never did this, plus the control arms, ball joints, bushings and the shocks were all replaced. In two wheel drive it doesn't do this. It also vibrates alot when accelerating in 4x4.I thought perhaps a control arm was bent but it would do it all the time. Also the engine clicks alot more when its cold. Any ideas guys? Thanks in advance.
1 - 6 of 6 Posts
Well you basically said that they had replaced everything I was going to suggest having a look at. Just like Hunter and NWRQC, bring it back in and tell them that they will need to make everything right on your truck.
Post up if everything gets rectified and you find out exactly what it is.
Good luck.
Did they do a 4 wheel alignment....or at lease check the 4 wheel alignment?
1 - 6 of 6 Posts
