Pull headlights out bought the only way. Look in wheel well you'll see an access panel open it theres a white clip in there believe you push it up (sorry just did it so many times its a habit ) if it don't go up then it will go down.Now remove the plastic radiator cover its just got push pins in it so tug and it will come off. Now for the 2 bolts you do not have to remove grill i mean you can just makes for a lot of unnecessary work. They are 10mm one is right on top of the headlight the other you'll need a long ext for it look down inside with a flashlight you'll see it. Remove them both and you'll have to tug and pull i found that if you take a cloth place ut over a flat head screwdriver and GENTLY insert by the back end that helps a little. Goodluck
