1 - 2 of 2 Posts
Hey guys, Need some ideas here:
Bought an 03' Ram 1500 Quad cab 4x4 in June, its been great. but now with the weather changing i'm noticing it doesn't have much in the way of heat. And I get a whiff of coolant when I turn it to from cold to hot. but usually just a whiff and its gone. It isn't consistent.
AC works great, blows through all the right vents, I pulled the fan and checked the recirc door, seems solid and fine. both heater core lines are a comparable temp. Not losing any coolant, but I get that little whiff of it when I turn it to hot.
Temp gauge is steady right where it should be.
Ideas, options, theories...
Did you check the blend door, as well? They have a history of failure and will result in either no heat or no cool air, depending on how they're stuck.
1 - 2 of 2 Posts
