1 - 4 of 4 Posts
ok well i have a 2012 hemi with maybe 3500miles on it
i have S&B CAI,HID headlights and 14'' magnalow muffler without the resonators with 33s
well i scanned my truck when I reprogrammed my tire size and these 2 errors came up
P2096 and B162C
P2096 is DOWNSTREAM FUEL TRIM SYSTEM 1 LEAN which is usually the driverside 02 sensor after the cat, But its a new truck , could this still be the problem??
B162C is LEFT LOW BEAM CONTROL CIRCUIT HIGH ok so what does that mean??
my HIDs work fine
Thanks
P2096, try to reset your codes and see if it comes back
B162C, are you running a wire harness or canbus HID ballasts?
Discussion Starter · #3 · (Edited)
i did but im offshore never looked and yes i have canbus HID
i have the quad headlight
Have you ever figured this out? I know this is an old post from 7 years ago but I too have a 12 Ram with led and have had the b162c since I bought the truck even with halogen. Both lights work on halogen and both with with led. No extra relay harness or anything. Both lights work I just get this code. Even after clearing it. Maybe an alfaobd error detecting it?
1 - 4 of 4 Posts
