Ok, so my cam caps broke, leading to a top end rebuild on my 07 dodge ram 1500. I first attempted making "wedges" for the timing chains, but on reassembly my driver side chain slipped. I ended up removing the rest of the front end, and replacing a chain guide (not sure if broke while removing head). First let me start by saying my engine was at TDC based on these 2 facts. Notch on balancer was at TDC, and both cams V8 were at 12 o clock.
So since my passenger side was still the same, all I had to readjust was driver side sprocket. I turned my cam to 12 o'clock, put chain on, and locked it down..... I manually cranked engine 2 full revolutions,,, I ended up with my notch back at TDC line, and both Cam V8s were at 12 0'clock. I figure I am good...? Upon putting everything back together I have a very rough idle / die situation.
1. Can my timing be off a tooth or two and cause rough / bad idle? OR is it either timed or NOT - no In between?
2. Is pinning the tensioners critical in the timing process given I was only readjusting one secondary chain? I did not do this. Again I only moved cam back to 12'oclock and locked it down.
Maybe I have a separate issue / connector / etc, I need to diagnose. If I rev the engine before it dies, it feels like there are times of "smooth" power band... Advise GREATLY APPRECIATED!
