1 - 3 of 3 Posts
1996 Dodge Ram 1500 5.9 Magnum
Upgraded the ACV sensor and TP sensor in the throttle body, new battery, new terminals, MSD ignition coil pack. Now i need ideas on whats next and please dont say intake, i know bro, its not there. Drop whatever i should do to it next that might need to get replaced. My TV cable and the two other cables are loose so could someone help me out with how to tighten those?
135650
135651
Loose ground wire to the left of booster, also a hose disconnected below and left side of booster.
You may want to explain what your issue is. ??? Not running ??? Missing the air intake tube that goes to the fender.
1 - 3 of 3 Posts
